Im installing a 14ff and Im not 100% sure were to set pinion angle. I kinda remember that in needs to be the same degree as the t-case. Im going to be using the stock d-shaft. If any one knows the conversion joint P# off of the top of your head that would also be extremely helpful.
cause his 14ff bolted right up.
