Unless you have a TC drop, it is pretty unlikely that your case is 10 degrees down. How much lift are you running? The angle of the driveshaft really only comes into play when you are running a CV axle and have to angle the pinion to point at the TC, at which point the driveshaft angle and the pinion angle will be the same or within a couple of degrees (some do that to account for axle wrap.
If you are using a conventional driveshaft, the u-joints have to be in phase as others have noted. Your angles at the pinion and TC should add up to zero. U-joints have limited operating angles, and methods like dropping the TC just move the problem from the rear to the front. Depending on your lift and setup, you may not be able to to run smoothly on a conventional shaft.
