B bluef4i Newbie Joined Mar 27, 2007 Posts 1 Reaction score 0 Location Landis NC May 19, 2007 #1 Does anyone know where you can get an aftermarket rear window lift motor for 86 k5? Also are all years the same on electric motors?
4X4HIGH 1 ton status GMOTM Winner Joined Dec 14, 2001 Posts 22,423 Reaction score 662 Location Fremont, CA. May 19, 2007 #2 Here is a p[lace to buy it. http://www.classicparts.com/prodinfo.asp?number=11-309 I'm pretty sure the only reason they list it as 78-91 is i believe all the 73-77 were manual windows but the gates are all the same.
adamforsythe 1/2 ton status Joined Oct 16, 2004 Posts 1,394 Reaction score 1 Location Maine May 20, 2007 #3 here is one that is cheaper http://www.partsamerica.com/productdetail.aspx?MfrCode=A1C&MfrPartNumber=4220&PartType=998&PTSet=A
BGKYK5 3/4 ton status GMOTM Winner Joined Nov 1, 2006 Posts 5,931 Reaction score 10 Location on the crapper... May 21, 2007 #4 Make sure it is the motor that is bad and not the drive cable. Try pulling the cable and flipping the switch to see if the motor runs OK.
