Rear seat belt bolts
Gskrot99
Registered Member
Feasterville PA
What is the best way to get them out? I know they are a common problem so what was the best solution?
HEAT...but you'd better have the rugs and seats out,or else risk burning the truck up...
GM used that red locktite on those bolts,95% of the time you'll bust a bunch of torx bits off trying to unscrew them,or in the case of the shouldered hex head bolts on older trucks,they usually tear out the floor around the weld nut,or shear off in the nut,if you try removing one without heating it up good first..
