I'm not at home to check, are the stock rear spring shackles 4" or 4.5"? I want to order some longer to add a touch of height.
Thanks!!
Thanks!!
4".
How long are you looking at going? What rear spring are you running?
I think longer shackles will LOWER the truck,so long as your putting them in the stock location...if they were flipped,longer ones will lift it some..
When I looked for shackles for my '82 k2500 I had a bit of difficulty finding stock replacements (but did eventually,at a local spring shop for about 25 bux each)..if I wasn't able to find them I could have gotten '88 and up shackles from parts stores in Dorman or at GM dealers ,they are a tad longer at 4-3/8" between the bolt holes,but all the other dimensions looked to be the same on them...Ford Ranger ones would have worked too,they are 4-1/2" ...
I'm running a 2.5 flip and stock 56's. I'm only looking for about 1" so nothing crazy. I'm adding a Zero Rate to the front and will need the longer shackle to level it.
Thanks guys!!
Here's some you might check out... I've got a set like this, that I haven't used yet... I built a set like ORD's that I'm running right now... But, these seem like a good deal...
Not sure if the set I have are the same brand, but they look just like these and feel pretty stout...
http://www.streetbeatcustoms.com/McGaughys/Shackles-Hangers/McGaughys-Drop-Shackle-33037/551054/
I was wondering about that, they don't look thick enough to be used with a flip.
It would be nice to also pick up a secondary benefit while doing this.Yes the longer shackle will reduce your angle. How is the progress?
