rear shock length
Bogger Man
White Pine Co. Nevada
I am thinking about getting pro-comp es9000's for inboarding the rear of the blazer. The blazer has a 4" lift and 1" body lift. Do you guys think these will work? Here are some pics of the top mounts and measurements to the axle where I plan to put the clamp on mount from Kert @ diy4x. I know I need to flex out the suspension to get the correct measurements, just hoping someone has sort of the same set up as this and could help, thanks.
