I'm sure there's a lot of posts about frame cracks around the shock mounts, but I figured I would share mine.
To repair, I Dremeled out the cracks to chamfer the edges of each crack. I chose not to drill out the ends like most threads; the whole frame's getting cut in 6 months.
I welded all the cracks with a lot of heat on each side of the frame. Chose to go with a double-sheer setup using brackets from Ruff Stuff. If you go this route, DRILL OUT THE BOLT HOLES FOR 9/16; that's the factory size for the holes in the shock mount.
Link for these brackets: http://www.ruffstuffspecialties.com/catalog/SBRKT-FLT.html
