k5ryder
I have a 85 K5 Blazer with 10 bolts front and rear. Stock height. I'm looking at lift kit springs and for the rear my options are 52" or 56". How do I know which ones I have and which ones I should order?
All K5s have 52 inch springs in the rear stock.
Thanks.All K5s have 52 inch springs in the rear stock.
with a shackle flip and 56''s that would gain a pretty good amount of lift correct? I'm just looking at a 4" lift and I want to replace all of the leafs.This is true. A lot of guys running a shackle flip use 56"s as an upgrade though. 64"s off a GMT400+ are popular also, but probably more complicated than you're looking at though.
OK. I'm just looking for 4" of lift and all new spring packs. So I will stick with getting a new 52" 4" lift spring pack. Tough Country seems to be the most popular spring packs from what I can tell.A shackle flip will get you 4 inch with stock spring. If you add 4 inch springs you will get 8 inch.
rear driveshaft angles down from the pinion? hard to describe. if zero degrees is when the driveshaft is parallel to the pinion, and positive degrees is when the driveshaft points at a spot under the truck further back than the spot the pinion points at, (zero they both point at the same spot), the angle is negative (driveshaft points at a spot, t case, further forward than where the pinion points.
