I've been having problems with my brakes occasionally pulling to the left. All the pads are new, etc so I'm beginning to suspect something is moving around. I checked and tightened all the front spring bolts and I'm in the process of doing the same in the back. As I'm taking it apart, I noticed this:
This is a pic of the underside of the spring perch. You can see in the pic that the spring bolt is in the hole, but it isn't exactly a tight fit. Is this correct? I thought it was supposed to fit tighter than that.
It's hard to tell if there has been any movement but it seems possible...
but that little l ooseness should not cause an occasional brake issue.
