I don't even run those anymore, I removed the bolt and bent them out so that they will still keep the leaves in line but won't inhibit flex.
Having said that, my rear flexes more than the front so I needed as much flex as I can get from the front and running the overload helps a lot (though mine is low enough that it sits on the overloads at ride height).
