buckmtn
I am putting an Eco bit shackle flip in the rear of my k30 trail truck. My question is how many leafs should I remove from the stock spring pack to get better flex. Also cut the stock shock mounts off the 14 bolt and moved the mounts up to the centerline of the axle. The shackle flip should give me in the neighborhood of 4-6" lift. Since I moved my bottom shock mount up 1-2" should I get a shock for a 4" lift?
). I ran 5 and no overload on my first set and killed them after 2 runs, the second set has lasted a little longer.
