It's time to fix the saggy rear in my ride. I was wondering if anyone with a 6" lift could measure from the center of the wheel mounting surface to the center of the rear fender lip. I have a 6" block, and I'm planning a shackle flip and I want to level the truck out either with a flip + 2" (probably Tuff Country EZ Ride) spring or a stock height replacement spring.
Right now I've decided to stay with a 52".
Up front I'm probably going to hold on to the current 6" spring until I hang a bumper on the front of the truck, but if it isn't leveled out by then, I'm considering dropping it to a 4-5" spring.
Right now, the rear springs are clearly arching upwards, they will probably fall to pieces when I unbolt them to do the shackle flip.
Also, can anyone recommend a retail site for Tuff Country gear. So far I've found a local store that doesn't even run a website, and suspensionconnection.com
Here is a side view:
