Currently my truck has a 6" lift - blocks in the back, not sure up front (bought it like it is, and the guy I bought it from didn't do the lift).
Now, it seems a lot of guys dislike blocks because, I'm assuming, they can slide out, don't allow as much articulation, and seem like they increase the chance of axlewrap (more leverage due to the block). Now, I'm not really "in" on the best methods to achieve lift, so don't be too hard on me. I'm thinking about picking up a set of diy4x's shackle flip kit, which would equate to 4" of lift, but I'm not sure how to pick the other 2" up. I was thinking a 1" zero-rate for the rear, but as it sits now, the rear end is a bit saggy, and adding a 1" zero rate would cause it to sit level (so I really need 7" of lift). Can I go with a longer shackle to pick the extra 2" up? Shackle flip kit (4"), 1" zero rate, and new shackles (2")?
Here's a picture of the rear suspension as is (camera is held level):
Not sure if everything is supposed to be canted/angled back that far? Wheel seems to be pretty centered up in the wheel well.
This is another stupid question, but when one mounts the shackle flip kit, does it go in the same spot the stockers were sitting at? Does the location vary depending on other variables, in order to get the best shackle angle? At that, how does one determine the best angle? I'd think it would be at the position where the leaf spring side of the shackle would be just short of hitting the frame on full extension, but I'm not sure.
Now, on the front suspension...like I said, it's a 6" lift, but I'm not sure if they're different springs, or what.
Pics of the front suspension as is, and the shackle:
I'm not looking for monster articulation or anything, but if I can get rid of the blocks in the back, I'd like to. Ride height is fine for me right now, as 35s are all I plan to run for a while until I can get something stouter than the 10 bolts under the truck.
