I just installed an ORD shackle flip and 56" springs. Measuring from center of hub to fender well in front I'm 27" in the fron and 24" in the back. Whats the best way to fix this? Add a leaf or longer shackle or both?
I just measured the old spring pack and it as 2 1/2" think and had a 4" block the new one is 2" think, stock shackle is 4" so I'm thinking a 5" should put me right where I need to be right?
First, you need to look at how many leaves are in each, you may look into adding one into your rear spring pack.
Second, a 1" longer shackle will lift the truck 1/2". It isn't a great way to get more lift but in this case you are better off with a longer than stock shackle. Beware that this will change your pinion angle too.
As mentioned, a zero rate will give you 1" more lift and putting the overload back in will raise it up some too (not sure why anyone doesn't run the overloads, they prevent the springs from overflexing and help axle wrap).
Finally, the front springs may settle a little once they're broken in, just more stuff to think about.
I was afraid using the overload would prevent flex but I would put it in before I put in a zero rate
you could always throw the overload back in too, and just put it in upside down. same theory as a zero rate, but its free!
