Rear sway bar
TJ1978
I have MANY questions
East Valley, Arizona
By the description this should work for 78’ k5, do you guys agree?
also what is a good option for the front? The ORD disconnect seems to only be used for cross over steering with Dana60. I have neither.
I have the disconnect on mine. No crossover or D60.
Really? I messaged them and didn’t hear back initially, then I read their quick disconnect only works on cross over. I couldn’t find the front sway bar on their website for NON cross over steering. D44
I don't think they sell the regular front sway bar. No demand or not enough. I only have the factory front and added ORD disconnects. Which I have bolts in, since supplied hitch pins wouldn't go through the sway bar eye bushings
Makes sense. Can you recommend a sway bar that will work with their sway bar hardware? I can just call them later as well
nothing wrong with a factory one, I bet someone here has removed one and would sell it.
Local score:
Cleaned it up a bit.. just need to order the above ORD parts.
did you get the frame brackets? what top plate is on your front spring right now ?
Didn’t have them.
I ordered the two items from ORD I linked above. I should be able to install this sway bar into the leaf mounts I have already... I hope.
If yours are stock top plates.
Not sure if they ever went metric with those sway bar eye bolts.
1 1/4" head on that bolt
