Rear sway bar
Gopherkiller
Hi Guys, I pull a trailer. Anyone ever put a rear swaybar on their outfit? I have a 14 bolt full floater rearend. It would be nice to stick with chevy parts if possible. Any help?
if i remembe right the LMC truck has a rear sway bar for a blazer. or u might try and get one for a 1-ton or 3/4 pick up. not sure if they made one on them but hey its worth a shot right?
Well as it gose it gose and under it rolls heavey rubber bouncing on a head.
(hey i'm a poet)
I really worry about those LMC and other after market sway bar kits. Not so much about them fitting, but more about the diamiter and the steel the sway bar is made of. Here in Detroit, we are having a problem with those hotrod Mustangs snapping the sway bars under heavy exelleration, and poking holes in the fuel tanks! Really cuts down on your fuel economy!
You can try and get one off a 3/4 - 1 ton truck. like i seid not sure if they came with them, but it might work. or u can get one custem made. i have firend who did that for his duster and its as thick as my front sway bar.
(hey i'm a poet)
hey 79 guy my little poem is "Well as it gose it gose and under it rolls heavey rubber bouncing on a head. " its not much, but it works right?
(hey i'm a poet)
