I was going to put this in the body shop but, there is always more people in here. I put in a new tail pan (LMC) and I need to replace part of the floor.
1. The bottom of my rear post where rotted out the attach to the pan. I made an L bracket and welded it on. Do I need to brace it anywhere else, or will my bracket and the floor be strong enough to keep it from bending?
2. I am going to use flat steel to replace parts of the floor. What is the best way to do this? Make the edge of the original floor flat and butt them together and weld them or over lap. Do I need to weld the whole joint or do I spot weld and use seem sealer?
. I ordered a new one, should be here in a few days.
