I went about replacing the manual crank handle assembly on my 87 because it was broke. I also replaced the felt on the window tracks on both sides, and in the process of replacing the the outer stripping also. Have two problems after i started re-assembling. The actuator is really close to hitting the glass, maybe it was that way before, but it looks sketchy anyways. The other issue is the window won't roll down all the way. I did have this problem before as well. I can't tell what's preventing it from going doing the last two inches. Any suggestions?
![20210721_181830[1].jpg 20210721_181830[1].jpg](https://ck5.com/forums/data/attachments/361/361980-f3cf05a6991e478ddf82599cdd3b9a18.jpg)
![20210721_181832[1].jpg 20210721_181832[1].jpg](https://ck5.com/forums/data/attachments/361/361981-7d4ff05b4667c38195d3c979a00ff684.jpg)
![20210721_191338[1].jpg 20210721_191338[1].jpg](https://ck5.com/forums/data/attachments/361/361982-e73d1931619c96d1b4bbaeda76987a38.jpg)
