1990_Suburban_rigride
Newbie
The electric rear window on my 90 Suburban keeps getting stuck halfway up/down. I'm certain that it is because of the track is getting caught on the latch handle, because the only way I can get it to roll up/down is to push it outward with the cover off when it gets to that point. I took off the cover on the tailgate and found that a small wheel that helps push the glass out with the help from the force of a even smaller spring. The spring was broken. LMC dose not carry this part so I fixed it with a spring from a clothespin. Still doing the same thing. I will add that my weather stripping is about non-existent from dry rot but I dont think that could cause the problem. Any advice?
