wheeler
Hi, so i just bought an 84 k5, and among other small issues, the back window does not go down. I knew when i bought it that it was a problem, but i think i got a good enought deal. The lock cylinder is missing out of the outside crank, and the crank does not feel like its making any contact. The guy i bought it from said it needed some kind of dogbone looking piece in the crank assembly, but it could be manually opened from the inside with a screw driver. Short of unbolting the regulator and removing the window, i dont see how to get the window to go down. Can someone please explain how to do this, so that i can easily get into the back. Thanks.
