falcon
Registered Member
Hi guys, I need to put new seals in my rear window in a 86 k5 blazer. While I'm at it I'm swapping the window itself for a better replacement that i got from another blazer.
How exactly does the window come out? I have the inspection cover off the tailgate, and I see the 4 bolts that attach the window "frame" to the arms that raise and lower the window. After I remove these 4 bolts, what else needs to be done so that the window will pull out?
Also any tips for removal and installation of the new seals? It may look a lot easier once the window is out.
TIA
TIA
