Jessie James
So my rear window works fine, except it stops about 1" from the top when I roll it up. As a result, water and exhaust comes in.
I can push the glass all the way up into the channel with my hands, but as soon as I drive any bump causes the glass to drop back down so that it's cracked open again.
Is there a way how to adjust the height of the glass as it goes up, or is there something that may be broken or missing which is causing this? I looked at the gears and such and don't see anything obvious...
I searched but unfortunately can't find anything on how to adjust the height of the glass (but boy, there are a lot of people having other problems!)
I can push the glass all the way up into the channel with my hands, but as soon as I drive any bump causes the glass to drop back down so that it's cracked open again.Is there a way how to adjust the height of the glass as it goes up, or is there something that may be broken or missing which is causing this? I looked at the gears and such and don't see anything obvious...
