rear window switch
76_gmc
Enterprise, AL
Can anyone help me in locating a power window switch for my 84 K5 Chevy Blazer. The window will go down, but not up!
There is a switch inside the gate that wouldn't allow the window to go up if the gate is open. Sometimes these switches go bad and other times they just need an "adjustment" with a swift rap with a screw driver handle.
If that don't work ...try LMCtruck.com they have all kindsa oem type replacement stuff.
yes it does ! that's one of those sites where ya hafta be careful not to spend millions!
X2 I just bypass all mine. The thermal switch can give you problems if the window is sticking alittle going up. Both mine are bypassed, but with my fulltop, the window goes up in the winter (after 30 minutes of anger) stays there till spring.:haha: Then it's soft top season.:D
While you're in there, check to make sure the rails are lubricated. They tend to get sticky and this may also contribute to the window being slow or getting stuck going up if the motor is alive and trying to work.
