Rear window.
SwedeBlazer
Sweden
Is it the same rear window on a -74 Blazer and from a newer Blazer?
I moust get a new one, and here in Sweden is it moust likely easier too find a window from a newer Blazer.
Thanks.
I believe that it was the same up till 91.
After that I am not sure if they retained the same with the full body no removable top model.
</font><blockquote><font class="small">In reply to:</font><hr />
3rd gen window's are different, they swing up don't they?
[/ QUOTE ]
WTF? /forums/images/graemlins/confused.gif
Eric what do you mean WTF? /forums/images/graemlins/tongue.gifare'nt 3rd(92 up) gen rear window's like the s-10's on a hinge at the top?
sinchphoto,Thank You......Eric /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
Yes all second gens 73-91 are the same and should be interchangeable. I have done the research to replace mine. Someone told me that the Suburbans are different but the glass in my blazer is from someone that pulled it out of a burb (so he says, but it fits) CHECK the angles on the sides on the glass and the mounting base.
yeah I have a 97 yukon, same body style as the 92-up blazers,tahoes,yukons... They should have the rear glass that lifts up on hinges, unless you got the barn doors offered as a special order I think.
