... If you open the tailgate, then click the latches closed manually, you can roll it up/down onto a work bench to get to the pivot points.
Ever notice how the guys with power windows want manual and the guys with manual want a power rear window?
You can also jumper the connector for the safety switch (blue wires, IIRC), then just leave it that way. We're not idiots, we know when we should or shouldn't operate the window![]()
I am definitely not bypassing that switch. It has NEVER given me any problems, just tells me when myself or someone else didnt' shut the tailgate properly.
I bought an a1cardone rebuilt motor at napa. Did not change anythig else. Thing flies up and down. Under 5 seconds each way. The outer seal was also wedged when I was done. Took it out for now.
