HellsK10
Registered Member
I recently had my '85 K10 in my garage for a fluid change, gaskets and spark plugs. The emergency brake cable was also adjusted to reduce some slack (still has quite a bit). Anyhow, went to back it out lastnight, no problems; pulling forward however is another issue...it drives like I'm dragging a concrete barrier!
I pulled it back in, jacked up the rear and spun the drivers wheel...it spins fine backwards, but as soon as you go to turn it forward it clunks! Drums aren't locked up...ideas?!
