Mike83
Registered Member
Ok so the junkyard i got some spider gears from said they were out a a gm 10 bolt from 88 blazer, mines a 89, only difference i know of is the 28 spline to my 30 spline. the gears are a tad big in diameter and the teeth dont match at all so they wont go in, this rearend is getting welded either way so perfect fit was not important. anybody ever weld anything else inplace of the spiders because of a lack of parts?? might have correct ones later but just in case.....ANY IDEAS YOU GUYS???
