Bridaddy77571
Newbie
Any body know the proper way to install a complete rearend to a 93 k1500 blazer.
I.E. do you load the springs by jacking them in upward position or keep in upside down u shape before tightening u bolts to axle
Same question for replacing with same shocks.
When I replaced the rearend it changed the distance from the drum to the ground while jacked up by the frame had to jack up quite a bit more than with the old rear end to get tires back on. Plz advise
