patrickgraven
Registered Member
so I broke a couple of teeth of my rear ring gear. I have a 10bolt (i know upgrade, but its not in the budget) and I got new ring and pinion with everything to redo it. However I have begun taking the axle apart and I can't get the center section out. I have removed the axles and the caps, is there somthing im missing or a trick to getting it out?
