Rebuilding driveshaft question about u-joints
sandawgk5
3/4 ton status
Kitsap County PACNORWEST
As you all know I busted my driveshaft and killed the u joint last weekend. Well readymix had some drivelines that he was not using so I have one to fix my broken on and another for a spare. I want to replace all of the joints on these shafts they are stock front shafts with CVs. Question are all of the Ujoints in a stock front shaft 1310 and can I replace them with the forged spicer life series. Would you recommend greaseable or non-greasable for a driveline. I know I run non greasable in the front axle but that does not turn all of the time. I want the forged joint cause my last one broke and took the shaft. I run a welded front so it prolly wont do any good but I cannot afford a HAD shaft right now just to change DL lengths later.
Thanks
Ira
The one at the axle side should be a 1310 ujoint but I believe the 2 in the CV are a different part number/size. I believe they are all available in the Spicer Life Series though. I personally use non-greaseable unless you do lots of mud or water.
Harley
Harley
The only mud or water I see is if it is on the road other than that I run rock and desert.:D Does anyone know the ujoint size for a front stock CV?
Ira
So it is the same as the rear driveline?
That is kewl I guess, Spicer makes a Life Series in that size and there is really not much of a cost difference between them and a regular joint.
So I need 4 S44 and 2 1310 to rebuild 2 front drivelines correct?
Ira
sounds right to me. before you go installing them, i would do some measuring just to be 100%
that and be sure you get the appropriate lock setup (inner, outer, whatever)
I found the non greasable part number and when I type it in to Napa online it gives me the greaseable joint only. I think I will have problems with the greasefitting hitting **** in the CV. Where do you buy Spicer life series joints that are non greaseable?
Ira
the grease fittings give me zero issues in my cv...they clear everything and i can get my pneumatic grease gun on them while they are installed. for a truck that sees offroad use(even dirt/rocks) i would prefer greasables.
