86chevyk10
Here are parts of my 350 im either going to rebuild or buy new crate from summit. This is my first rebuild, I had a spark plug come apart in one of the cylinders, I honed the cylinder and you can barely feel the scratch when you run your nail across it, does it need a bore job? The other pics are obviously the condition of my main bearings? As I said before, 1st rebuild, is that normal wear where you can see the copper? Any suggestions or help will be greatly appreciated!!! I dont want to rack up too much $$$ on bore/rework of heads/new pistons...etc where I approach the cost of a new crate 350. Any opinions? Thanks guys
