Hey guys,
I finally got my engine built, its a small block 400 bored .030 over. I am having a problem with the coolant surging and kinda seems like its boiling. Weird thing is both temp sensors say the coolant is no more then 190 degrees when its bubbling. I have one sensor in the intake(had fuel injection on it for a while) and one in the driver side head. Stock guage shows straight up in normal and the computer showed 180-195.
Is it possible that block couldnt take the .030 over and its creating hot spots. I have heard that some 400 blocks cant take an overbore or you should sonic test(??) the cylinder walls before boring, not sure about that last one. I used the 400 head gaskets and did check before i bolted the heads on that the steam holes lined up.
I have had the heads off before i rebuilt the engine, the only thing I did different this time was put in the coolant restricter metal things in the intake gasket. I thought it might help my carb fuel boil when the engine turns off. I even poked around with an infrared temp gun and the temp shows the same as the sensors to. It will even start to surge like that when you just first start it up cold and let it warm up. The heater hose even moves up and down a little by it self
Any ideas??
Other then that it runs good and has tons of power. Ive ran it like that for about 700 miles now.
Any ideas??
would help cool down
