Hey guys. I followed the instructions you gave me to double check/correct distributor setup, and sure enough...it was 180* out. It must have been at TDC on the intake stroke when I set it. Who knows...either way, it fired up with no problems.
Now for the badddd news...about 3 min into running the engine and beginning of cam break in, I noticed steam coming from the valve cover vents. I immediately shut it down knowing something was wrong.
I pulled the oil dipstick and it was grey...coolant was leaking into the oil somewhere. I pulled all the plugs and only the #6 cylinder plug was wet, so the culprit of the problem has to be there. Im sooo pissed though because I trusted that the builder of my engine would have magnafluxed the block and heads making sure there are no cracks. All new Felpro gaskets were used upon reassembly too. Maybe I will get lucky and just have a blown head gasket at the #6 cylinder...I have my fingers crossed. I am going to call the builder tomorrow and hope to hell he will stand behind his build...otherwise I will be fuming. After a year of build up and finally getting everything ready to go...this crap happens.
I am really wishing over and over that I built the engine myself so I could have checked and rechecked everything. Any input you have on a possible solution or what might be wrong, etc...feel free to pipe in. I am fearing the worst and that I will have to totally pull the motor again and be out all this time and more money...if the builder doesnt stand behind his work.
