ciffer
Here is the background on the story. A friend of mine purchased a small block from a guy on ebay, long story short, it didn't run right for my friend so he sold it to me cheap.
Here is what I have been told about the engine:
350ci .060 over
"RV" roller cam, unsure if hydraulic or solid
fresh rebuild, assembly lube could been seen in many areas of the engine.
Here is what I know about the engine:
It won't idle under 1500rpms
no power at low RPMs
pulls pretty good at higher RPMs
it needs a TBI compatible cam to work in my 88.
Here is where I need the advice. My older suburban which I am currently campaigning on the local mud bog circuit runs good but the motor is showing it's age. The current motor leaks/burns a full quart of SAE 40wt every tank of gas. I want more power and have a spare engine.
I can think a few options for the engine, run a leakdown test to see if the engine is sealing then install a TBI cam and hope for the best. The other option would be to tear down the engine, measure and inspect the bores, hone and ring the engine and hope for the best.
You guy's have have never disappointed me before, lets see what you got.
350ci .060 over
