Reccomendation for Dual Exhaust
i use to love dual exaust systems. but these days i have found a good flowing ypipe and single in dual out muffler will bark better in my opinion. as i like flowmaster sound. i have had both single muffler and dual muffler. single barks better. and this gives less problems with tcase clearence.
with your tbi fed vehicle if you go duals make sure thay stay away from the fuel lines and filter on the frame by the tcase. lots of places forget thay are there.
best option is go to a muffler shop and have them custom bend one to your liking, that way you dont have to compromise on what you want.
I have had both dual exhaust and 3" single. I had an 86 K20 factory dual exhaust no cat truck, I put 3" single exhaust on it. That was the only time I added exhaust and fealt a difference in performance. My buddy has an 89 V30 cc and he put dual 3"...sounds terrible and runs just as bad. Just thought I'd ad my 2 cents.
i but headers on my tbi with dual 2 1/2" pipes out the back and i could tell a difference. the shop i went to also ran all the pipes above the cross members. you can only see it by the collector and the gass tank. nice and quite inside loud out back.
I dont think there are any aftermarket true dual systems for TBI trucks.
You will have to go to a muffler shop and have a custom exhaust made.
but
IMHO A 3" single mandrel bent system with a good flowing Ypipe works just as good or better with TBI and is cheaper than dual.
Yup.. I'll more than likely take that route..
The ONLY thing I hate about a single system is the fact you have a Y-pipe...
but
X2.
I got a dual kit from JC Whitney for less than $200 for my 90 Burb with a TBI 350. I lost some pep on the top end, but made a difference in the low end. Pulls awesome until about 2500rpm then it gets sluggish if I've got alot of weight in back. True dual 2.25 inch, glasspacks (sets off car alarms) and everything stays next to the frame rails, so nothing is lower than the trans crossmember. I have the same setup in my wifes 88 Burb only with turbo mufflers. Not a huge difference between the old and new (had a whopping 3.5 inch single before). Only reason I replaced that one was the cat plugged up and the rest of the stuff was rusted so bad I used a set of channel locks and a hammer to pull it out.
ibeen lookin for a true dual system for my burban and i found one on summitracing.com, for about 325 comes with headers and all the pipes pre bent and fits 4x4 in our years..might check that out if ya havent made a decision yet.....i also plan on doin the tbi on mine after i get whichever exhaust i choose, maybe we can compare notes when the time comes
