recomendation for d shaft
88k5blazin
clark new jersey
Im gettinready to order d shafts from had and I have the option on the 1350 cv or the 1410 cv. I have 40in boggers and slightly modified 350 and lockers. 14bff with 4.56. Do u guys think the 1350 cv will be significant strengh for a mud truck or should I go for the stronger 1410
1410's can run at a higher angle 28 vs the 1350s 20.
I beleive the 1410 yokes have a little more material on them but the biggest pull for them is the fact that they joint has a wider cross section allowing more angle.
So if your shafts have a fairly steep angle to them, wich im assuming they do might as well spring for the 1410. Plus you can get the u bolt style yoke for your pinion
Given the choice I would always go bigger (thats what she said :haha:)
1410 for sure adds a bit of strength and more handles angles better.
Since the 1410 handles the angles better its strength doesn't drop like the 1350s will. U joints are rated at a zero angle. For every degree they drop some strength till they reach maximum operating angle.
