Hey Guys,
I'm hoping to finally get around to lifting my rig with my upcoming tax return and swapping in the axles I picked up earlier this year. Since I'm using a Ford D60 I picked up a driver's drop NP241 to go with it and I'm thinking I might as well do a SYE and get the driveshafts redone (buy once cry once). I'm looking at JB Conversions but I'm not sure if I should do their standard length or the super short version and if I should do a flange or one of the yoke setups? I'm also not sure what the difference between their 1310 CV yoke and their 1350 non-CV yoke is? I'm leaning towards the shorter version for the little extra driveshaft length it'll give me but I'm not sure beyond that. I keep hearing people say go flanged so you can run a CV shaft to eliminate vibes but I don't know if that's necessary with only 4"-5" of lift and 35's. The other concern I have is I'm planning on swapping in a 402 LS/4L80E next year which looks like it'll add 2" or so to the trans length and I don't know if that'll throw off the driveshaft angles enough to make the CV unhappy/start vibing versus going with a yoked SYE where I can hopefully keep the t-case output angle the same after the drivetrain swap... What do you guys think?
Truck is an '84 K5 with the 6.2 diesel and 700R4. I'm doing 4" TC EZ Ride springs in the front and a 4" shackle flip in the rear with zero rates to recenter the axles and will be running H2 rims and 315/70/R17 tires (H2 take-offs) on a '79 Ford Snowfighter Dana 60 and an '04 AAM 10.5 14 bolt.
Thanks,
Anthony
Thanks,
Anthony
