Recovery rope
blazenoffroad carries them we use the same thing exclusivly in our local mud spot best thing out there easy on drivetrain. that size is a little small for full size blazen carries a larger size. Or find a ship yard or rope supplier around you and buy it from them.
a friend had a rope similar once that his dad got in some oil field pipe pulling application and it was nice and stretchy and worked great. I'll see what blazin has to offer.
i'd go 1 1/2" nylon twist. any boat supply should be able to order it and splice an eye in each end. 1" is a little lite duty as mentioned
I beleive the rope is called Samson Braid. Although the one you listed is a little small for full size the stuff is amazing. Like a big rubber band, way better than a strap.
