Redneck Fix #879,298,001
justhorsinaround
3/4 ton status
- In Memoriam -
Northerish Phoenix, Az
So do you have a crack in your radiator along the seam of the end cap? /forums/images/graemlins/ears.gif Well do I have a quick fix for you for the low, low, low price of right about five bucks! /forums/images/graemlins/woot.gif
First ya yank the radiator out. Put it on end with the crack facin up. Here's the redneck part. /forums/images/graemlins/tongue.gif Grab the tube of Super Glue that ya have settin on some shelf in the shed or whatever. Slather a whole bunch of the stuff all along the crack and let it skin. If'n ya want for some extra insurance, then take some gasket sealant and put some of that all over the place. Then hike on in to the bathroom and grab your gals hairdryer and use it to dry the whole mess.
Throw the radiator back in the truck and bring the critter up to temperature without the cap on and let cool. Wiz bang your done and so far it ain't leakin.
/forums/images/graemlins/thumb.gif
It's amazin how necessity really is the mother of invention.
Good luck to y'all in the future.
Allan
for a hole in the core of the radiator, use bubble gum. not only will it seal the leak, but as the engine comes up to temp it will emit a pleasant smell. totally freaked out some of my competitors when i was racing my Monte Carlo. beat and banged up car, no windows, no bumpers, no exhaust, and the unmistakable aroma of Bazooka. /forums/images/graemlins/laugh.gif
[ QUOTE ]
why not just use a blowtorch and some solder and solder it closed?
[/ QUOTE ]Rednecks don't know how to solder,They use a roadflare and a coat hanger and weld it shut /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
Ahhhhh. That would require the possesion of a blow torch. This was the rummage around lookin for JB Weld, which I obviously couldn't find, idea that seems to be doin pretty well so far. /forums/images/graemlins/whistling.gif
Allan
hey it does sound like a good trail repair tip /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
Black pepper is cheaper and easier and you dont have to remove the radiator, or egg whites. Those are the lazy redneck fixes. /forums/images/graemlins/peace.gif
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]ROAD FLARE AND COAT HANGER???DOES THAT REALLY WORK?
I've used coat hangers as a filler rod with a torch so if the flare gets hot enough I guess it could... Coat hanger rod doesn't work real good but it's better than nothing. It has alot of impurities and no flux.
A word of warning. Do NOT try to solder on that radiator now that you have applied super glue to it! /forums/images/graemlins/eek.gif When super glue is exposed to flame, or the heat of a soldering iron, it will release isocyanate gas. That's the stuff that leaked from a Union Carbide chemical plant in India several years ago, killing thousands of people. /forums/images/graemlins/yikes.gif Just a tiny bit of it will make your eyes and sinuses burn like they're on fire. /forums/images/graemlins/frown.gif
I limped home once by sealing a leaky radiator seam with some stuff called "Shoe Goo"--its made for fixing shoes,its made by the same folks that make "GOOP",they have several types"Plumbers Goop","Sportsmans Goop",they all seem to be about the same stuff,looks like clear silicone caulk,but the stuff works great--its holding the soles of my trashed work boots together for six months now! /forums/images/graemlins/eek.gifand they were torn almost right off the leather uppers!.It works on rubber radiator hoses,it stretches instead of cracking when flexed.I would normally use J-B weld but that was the only stuff handy that day.I did solder it when I got home--it was a real bear to get that stuff off so the solder would stick--maybe I should have left it on to see how long it would have lasted!It works on house plumbing,so it should work on automotive,right? /forums/images/graemlins/whistling.gif
So it wasn't your thermostat. I wonder how long it will hold up. Anyway , call me, I still need to give ya those fans /forums/images/graemlins/thumb.gif
