Refinish/Restore Old Tools
ARAMP1
Aviator Extraordinaire
Memphis, TN
After recently purchasing a snap on ratchet and finding out that some of their hand tools, to include their ratchets, are no longer made in the USA, I started thinking about a few things.
I thought about my grandfather and how he always fixed things. He never had a lot of money or possessions, but after he died, my grandmother gave me his half inch drive craftsman spinner/speed handle. Now, I'm not going to get on a made in the USA quality vs imported, but the quality of that old craftsman driver is amazing. I'm sure I'll be able to pass it down to my grandkids. I don't know I could say the same thing about a similar craftsman product made today.
Anyway, to make a long story not as long, I decided to buy older tools instead of buying new. I needed an extra set of wrenches and the old Plomb brand had always fascinated me. And, if I can find them and they've lasted since WWII, they'll probably last through anything I ever do to them. I've decided to slowly piece together a wrench set from whatever comes up on ebay and other forums I visit. Here's what I have so far.
As you can see, some wrenches like the one inch combo are in almost perfect condition. Others are not. I thought about just finding what I can and then replacing them with better examples as they come a long, but I'm wondering if I could instead have the wrenches refinished somehow. There's clearly a finish that has worn off on a few of them. If I can't do the original finish, I've thought of chrome or duracoat too. :dunno: Any thoughts/ideas?
Any kind of "plating" will affect the wrench sizing in the open/closed ends so i'd be careful there.
True. I would expect to remove the old finish before putting on the new.
Not every kind of plating will be as thick as the other so until you have it plated you won't know if the sizing is correct.
Platers can tell you with a good deal of accuracy how thick the plating will be. They have it down to a science.
Powder coating would affect the size of the open and box end more so than plating
Sandblast/powdercoat....
I would check around your area and see if there are any businesses that do cad/zinc plating. They should be able to strip the old plating and then re-plate the wrenches.
X2 There is an electo-plating shop next door to the machine shop I work at and we do work for them from time to time. The owner has it to within .005" on their mass production work. I have to machine down 400 1" shafts on the end about 2" back because they're plating them and the handles won't fit back on whatever the customer is doing with them once they're plated. He knew exactly how thick the plating was going on.
