Did my Reid knuckle swap today in preparation for my ORD crossover. Bought a CPP 50014 2WD Steering box from Summit. There was a 50004 steering box, in the box marked 50014, so that didn’t get put on this weekend. Looked like the correct box except it mounted inside the framerail.
I torqued my ball joint connections down to 100 ft lbs and the preload to 40 ftl lbs. Is that correct? Lateral knuckle movement sure is tight.
Charlie
Charlie
