I have my compressor in a side room of the shop and want to turn it on and off from the main room. If you have a big compressor, it probably has a magnetic contactor and separate unloader for the head pressure. In that case, all you need is a switch wired in series with the pressure switch and it can be located anywhere. The unit I'm running now has the integrated pressure/contactor/unloader. It's kind of similar to this:
Since I don't want to just cut power to the compressor while it may/may not be running, there's 3 options I can see:
- Build a cable drive for the power/auto switch that flips it up and down. The cable would only have to be like 3-4 feet to go through the wall, but ideally more like 6 so the handle ends up near my drier, regulator and reel stuff.
- Create a sort of "OR" logic to cut the power to the compressor only when it's not running. So once the remote switch is flipped off, a relay stays engaged until the cycle finishes, then cuts power. One drawback is that the relay will see full stall load when turning back on, assuming the pressure has dropped below the cut-in pressure.
- Convert the compressor over to style with separate pressure switch, unloader and contactor.
