I'm doing it. Trying to be done in a week. We'll see.
First off, does anyone know what the terminals are that are used at the power door lock relay? I want to say that they are Delphi 56 series (or something similar, 56 series is what the "normal" fuse panel firewall connector uses, the late R/V's used a different terminal IIRC), but I'm not home right now to look at them, and even then I'd have to measure the connector dimensions to try and figure it out. That would allow me to order them quickly.
Already bought a cheap RKE kit off ebay, like this https://www.ebay.com/itm/Universal-...375321?hash=item1c7d20a399:g:uiMAAOSw4CFYpcbZ For $10 or so, figured it would be worth the gamble. If it works but doesn't work well, might look for a more expensive version. They are fairly cheesy, no bolt holes or anything to mount it, but it came as pictured, and with batteries in the fobs.
Just out in the open I got about 100' of distance testing it out, but I'm not expecting nearly that once it's mounted in the truck. The antenna is so short (~6"), getting clear of all the sheet metal is near impossible.
The instructions are almost worthless, but pretty easy wiring with our trucks if you have PDL already. I want to do it cleanly, so I'm going to replace the existing terminals at the PDL relay so I can add the two wires from the RKE (up/down trigger) to the existing relay without butchering the wiring. I'll use a small two terminal connector of some sort to be able to disconnect the RKE module from the PDL relay if I need to pull either one out. I tested it with the RKE connected this way temporarily, and it worked fine. Just those two wires for up/down to the PDL relay, battery +, and ground.
Not going to use any of the other "functions" of the RKE module.
While I like wasting time on improvements with minimal actual value in any case, during the winter when I use the truck camping and hunting, if I lock the doors, it's a real chore to find the key hole when it's pitch black. Not to mention, its normally raining/snowing/freezing, and the truck is often covered in wet mud, so avoiding all that as much as possible would be nice.
I'll try and get some pics of what I'm doing when I figure everything out.
