jones
Everything looks right according to nova resource and third gen.org. Went to hook up the battery and got an a$$load of sparks and the solenoid engaging/dis-engaging rapidly.
I've got power from the battery to the BAT terminal,from the BAT terminal to the starter(then jumped to the "s"terminal on the starter via a jumper strip),all wires originally on the large starter terminal are also on the BAT terminal on the solenoid. The purple starter wire to the "s"terminal on the solenoid.The NEG battery cable is grounded to the frame.
Did I overlook something? The solenoid is an AC Delco unit p/n un939,I think,which is mounted on the firewall next to the A/C box.Also have engine ground from the rear of the pass.side head to the firewall.
I don't see why this isn't working.Your help is appreciated greatly,guys.Thanks
