I installed a BOA Security remote start w/keyless entry in my '93 K2500 today. Everything works except that it won't actually start the truck. It will turn the engine over but it won't fire unless I put the key in the run position first. I talked to the company today but they were no help at all. The only wire that I can't figure out is the one it says to hook to the tach. I spliced it into the tach wire off going into the ECM like it said and then I tried it on the tach wire coming right off of the coil. Then they told me to splice it into one of my injector power wires and that didn't work either.
So my question is, where the hell do I hook this wire in?
I figure I'll call them back on Monday if no one here can help me out. If I do, hopefully I can talk to someone that has a freakin' clue there.
Below is a pic of the kit I installed. The model number is 256B.
Thanks in advance,
Rick
Thanks in advance,
Rick
