Removed Stearing wheel to tighten those pesky nuts and......
does it still make the "click" like its switching? You may have knocked the rod that goes to the switch off track. The switch is operated by a rod that goes down to the lower part of your steering column. see if its still in place down there, and up at your multi function switch.
thanks
it does not make the clicking noise anymore.
i haven't had time to take it back off. so if the rod is loose or not attached it will stop clicking/working?
thanks again
Yea. Basically there's a metal bar that connects to the bright switch under the dash... You maybe able to just remove the bright switch and not have to tear apart the column again. I was swaping bright switches a few months back and when I pulled that switch off the bar basically falls right out. Its a little plastic piece under there that has 3 wires goin to it by the ignition switch
