xpndbl3
Opening this up for discussion on removing a leaf out of my pro comp 6" front leaf springs or just buying the Tuff Country EZ ride ones. I'm swapping in a 5.3L engine with aluminum heads which will be 120 pounds lighter than the stock 350 tbi. As of right now with pushing down on the bumper with my 300 pound self, I can't get the front of the truck to move more than 1/2". It is far too stiff and this motor swap will only make it worse. I've seen guys pull leaves out before, just wondering which leaf you remove. If it lowers the truck a bit as well that would be great too.
I took some pics and wanted your opinions before I just remove one or buy aftermarket springs again.
Good luck getting those spring packs apart!
so I'm trying to bring it BACK to being all stiff and low-travel
