The heater only wiring is easily installed , if you have access to any truck from the 70's on .
The harness plugs into ONE black plastic plug near the radio wires ( directly from a/c /heat fuse ) , and then runs through the hole in the dash to the stuff underhood .
That power drop can also be used to draw power for your simple switch .
