Why are you guys removing the mill scale?
when ever I have to clear something sticky like that I take a can or two of brake cleaner shoot the **** out of it, while it's still wet I light it up with the torch, then after it cools down I use the rolocs and its good as new! The brake cleaner and torch dries it out enough that way the rolocs don't booger up and smear the still dirty area to the clean spots
i'll have to give that a shot next time, thanks!it'll eventually fail under a topcoat system... my welder/fab bud who's been doing this stuff for almost 50 yrs has seen it and when it comes to steel and fabrication, i trust nobody more... it may not happen for awhile, but it does.. also my background in proper bodywork coating procedures tells me the same thing.. sure you could slather some rustoleum on it, and it may last a long time, but it's not the proper way to do it...
