Removing Knock Sensor from an 89
MrTruck805
Santa Barbara, CA
Hi All,
I'm trying to replace the knock sensor on my '89 350 (Dealing with passing smog test and OBD Codes 42 and 43). After I disconnect the harness and put a socket on it, all it does is spin the sensor within its housing. I've sprayed it with a few rounds of penetrating oil, and put needle nose vice grips on the housing, but no luck. There isn't a whole lot of room to try something like hitting it with a punch.
Anyone run into the same issue and have a clever way of getting it out?
Thanks!
